intermittant high idel
Old Sep 22, 2008 | 06:08 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
Default intermittant high idel
95 Blazer 4.3L Have a high idel when Veh. is cold. Replaced TPS, IAC,& Coolant Temp Sensor also checked for Vacuum leekes, Still continues. Have recently replaced Spider injector and replaced all vacuum lines. Any suggestions? Thanks
Old Sep 22, 2008 | 07:17 PM
Default RE: intermittant high idel
Have you checked the EGR valve?
Another way to rule out vacuum leaks is to block off all vacuum ports on the intake. If the high idle continues, then the vacuum driven accessories are not at fault.
Old Sep 24, 2008 | 04:00 PM
gscrippler's Avatar
ok i'll look into that, To your knowledge is there any other sensor that might effect the idel?
Old Sep 24, 2008 | 09:28 PM
Nothing besides parts you have already thrown on.
Old Oct 5, 2008 | 05:57 PM
gscrippler's Avatar
Ok, Hooked up to TECH 2, Air intake temp sensor was reading -40F checked voltage and found that 1 of the wires was broken inside the insulation so replaced the plug (connector) next morning it high idel again while high ideling hooked up to TECH 2. TPS was reading 6% open and the voltage was off.63 i think, I had recently replaced the TPS while trouble shooting another problem. Anyway put the old one back on and the voltage seemed a little better .55 so I will try this out and see if it cures it. Will probably try a new another New TPS I notice the shifting from 1st to 2nd is a little rough it was much smoother with the other TPS.
mxpxpunkrock1987
Jul 1, 2011 01:51 AM
FreeBird
Feb 25, 2008 08:30 AM
yazan84
Dec 30, 2007 11:19 PM
95BlacerMississippi
Jun 25, 2006 05:43 PM
PINTO MAN
Jul 16, 2005 12:08 AM
