Intermittent start problems need some help
I have a 1993 s10 blazer, 4.3 CPI v6. Problem is that sometimes, after driving for a while the engine will sputter and die. I have replaced the following
-fuel pump and sending unit
-CPI unit including the regulator
- filter
-fuel relay
-gas tank (had a leak)
- few sensors that has to do with spark
All this I did not to long ago. So here's where I'm at.
After driving for a while it will sputter and die. I check a fuel pressure at the rail and have proper pressure. So I pull a plug and have spark, but the plug was completely dry. I shot some starter fluid into the intake and its tried to fire. After sitting for a while it will start then run like crap and die. I think it's a fuel
Problem but I'm not sure what or what's left to replace! Any help is greatly Appreciated!!
- filter
-fuel relay
themoneypits
07-14-2013 12:39 PM
fudggj
11-09-2011 08:24 AM
davidluzader
03-01-2010 10:25 AM
scottyk
03-19-2007 11:32 PM
