Intermittent starting problem
Old Jan 14, 2009 | 07:49 PM
WolfPack's Avatar
Default RE: Intermittent starting problem
Try giving the bottom of the tank a good whack with a rubber mallet. Mine started right up after 0 pressure at the test port. Unfortunately the pump died completely a few days later [:@]
And autozone/advance have pumps for 250-300, and you can order a Delco online for 280 if im remembering right. Where/why did you pay $500?
But I still dont think its worth paying someone to do. Its not hard, just gas fume-y.
Edit: Two problems. One...youre still getting a flashing security light. So to confirm its the passlock system...you should be getting a crank, fire (RPMs shoot up), die. If its the fuel pump, you just get crank crank crank crank...no rpm movement. Second, if you get a security light, I know it kills fuel to the injectors, but does it cut it before or after the test port? Im just thinking theres no way to know if its the fuel pump or not if you have a security light killing the fuel flow signal.
Old Jan 14, 2009 | 08:29 PM
848 Hooligan's Avatar
848 Hooligan is an unknown quantity at this point
Auto Zone it was a Delco
Old Jan 14, 2009 | 08:41 PM
mrafindley's Avatar
mrafindley is an unknown quantity at this point
Sounds like ignition switch to me be rough with the key when you turn it next time it wont start and see if it will crank up
Old Jan 17, 2009 | 11:29 AM
c5ce's Avatar
c5ce is an unknown quantity at this point
Well, the fuel pump was the problem. Installed a new pump and its running smooth and strong!!!
90K on the clock! That DOES sound familiar!!!
Old Jan 17, 2009 | 09:30 PM
WolfPack's Avatar
Glad you got it fixed!
cas
Mar 22, 2014 11:33 AM
IT Technician
23
Jan 10, 2013 12:31 AM
rdshiver
Dec 13, 2012 02:05 PM
abadinalbany
Sep 13, 2010 11:02 AM
AUEngineer
Sep 13, 2010 01:13 AM
