Issues with trans install
Old Jun 19, 2020 | 07:43 PM
Juggalonmd's Avatar
Juggalonmd is on a distinguished road
Default Issues with trans install
Ok so I got trans almost lined up I got one bolt in the houseing to the block. I've got one floor jack on a cart. (So I can move it around easier with the right surface, was the idea... Didn't turn out....) Also I have a bottle jack and a scissor jack to help transmission. But I can't get a good angle. Tried as many different ways I can think of but no luck. Any suggestions? I'm on the ground with jack stands holding truck up. pics to follow
The transmission is wanting to twist everytime I get close. The two bottom corners of the bell housing wouldn't mate so I went to bolt one up top
Old Jun 20, 2020 | 08:30 AM
Transman304's Avatar
Raise the back of engine up. Block of wood on oil pan and jack under it.
Old Jun 20, 2020 | 09:08 AM
Juggalonmd's Avatar
Did that and was able to get trans mated to block getting ready to double check what I have done and start putting bolts in bell housing in.
Heftynoma
Lifting Tech
22
Mar 4, 2021 08:06 AM
jkyle187
May 4, 2019 12:14 AM
N. Jensen
May 2, 2019 10:30 PM
91tbi4.3
Lifting Tech
19
Dec 14, 2012 06:58 PM
rcravincase
Mar 18, 2011 08:27 PM
