its 2018 what intake gasket to use on 98 jimmy?
Old Mar 3, 2018 | 12:18 PM
int3414's Avatar
int3414 is on a distinguished road
Default its 2018 what intake gasket to use on 98 jimmy?
1998 gmc jimmy,pretty good leak antifreeze on ground,only want to do the job ounce,are we changing the bolts also,what gaskets?...TIA
Old Mar 3, 2018 | 12:31 PM
For the LIM gaskets will want to use the upgraded Fel-Pro set: Federal-Mogul Motorparts P/N MS 98002 T These have a metal carrier/frame for the sealing material.
When I did mine, I also bought new bolts. They were not that expensive.
I also decided to replace the fuel injection spider while I had it all apart. I had the one in my '92 go bad about the same age and mileage and thought I might as well do it.
I also at the same time flushed the power steering system. It was a lot less of a hassle than I thought it would be.
Edit: This is a very good write up of the whole process of getting at the LIM gaskets. Ignore the advice about scraping the LIM gasket surfaces. Also pay close attention to the description of the hidden power-steering bracket bolts. If I had I would have saved myself at least an hour trying to figure out how to slide the PS pump forward! LOL
How To Replace Intake Manifold Gaskets On A GMC Jimmy 4.3 Liter V6 To Fix A Coolant Leak - GM Truck Engine Repairs
Old Mar 4, 2018 | 10:09 AM
int3414's Avatar
thanks,i had found the 'how to do' with the nice pictures....thanks again!!
limited edition 1
Jan 27, 2023 11:07 AM
J.R. Clay
Mar 17, 2011 08:22 PM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
