Just changed out the shift solenoids..
Old Oct 1, 2017 | 09:27 AM
Gfreed's Avatar
Gfreed is on a distinguished road
Default Just changed out the shift solenoids..
Hey guys, so my transmission wasn't shifting at all past second gear and drive had pretty much no power/acted sporadically. Ran the CEL and it came back as short circuit in the 2-3 shift solenoid. Sweet, no problem. Changed out the 1-2 & the 2-3 solenoids. Put her all back together and drive still has no power but when I put it in 2 it drives fine! Way better than before where I felt like I was in straight up limp mode. In 2 I can get right to 45 mph no problem but you put it in drive and it's nothing. Just revs. Barely moves.
Please help!
P.s. I also replaced the filter and gasket 2 weeks ago. The oil that came out today was like dirty old motor oil.
Old Oct 1, 2017 | 11:27 AM
Transman304's Avatar
When you checked codes did you use a scanner for OEM software or a code reader or app on your phone? With what you described are the common 3-4 burnt clutch pack. Time to replce or rebuild transmission. Especially with fluid condition.
Old Oct 1, 2017 | 11:53 AM
Gfreed's Avatar
I just took it to AutoZone. Whatever scanner they had there. CEL is now off.
blazertom
Jul 30, 2015 08:37 AM
Tommer2
Jul 16, 2015 01:16 PM
drewblaze99
May 5, 2015 09:22 PM
jkfrost77
Oct 13, 2013 08:34 PM
akira19
Feb 16, 2010 09:15 AM
