Is the leak coming from Transmission?
Old Jan 14, 2013 | 09:56 AM
janddcunningham's Avatar
janddcunningham is on a distinguished road
Unhappy Is the leak coming from Transmission?
I have a 1997 Blazer 4*4 166k miles on it. I noticed it was leaking something under it. It smells kind of like coolant however it has a oily feeling to it. as I was looking under it it appears that is leaking oil on the drives side just under the coolant botte or so my oil appears to full and the coolant is full as well as the tranny fluid is full what could be leaking I had the intake replaced in 2011 due to a small coolant leak so is it possible that that could be leaking agian?
Attached Thumbnails Is the leak coming from Transmission?-th_mydroid327_zps20feace0.jpg
Old Jan 14, 2013 | 11:28 AM
ok now thinking maybe oil leak just had the oil line oil cooler lines replaced on it too back in 2011 could it be those? Would the manifold be leaking oil? I had the lower intake man replaced in 2011 as well around April/May.
Old Jan 14, 2013 | 04:03 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Its realy hard to tell from your pic but if its leaking from where the engine an trans is under the bottom couldbe the oil seal,It also could be leaking from either valve cover on the back or side then dripping down.If your oil lines were replaced it could be the where it connects to the bottom side of the engine.
scphill34
May 30, 2013 10:20 PM
BubbaBrooks
May 18, 2011 08:38 PM
importsky22
Sep 25, 2010 10:39 PM
Blazers.B.Kewl
Mar 28, 2010 01:54 PM
TAZ454
Jan 28, 2008 10:11 AM
