leaking lots of coolent
i cant find a bad hose the systum is bone dry right now and im at work so cant add water till lunch to see where leak is coming from and its my DD X-( puss its 27° out thining radeator is ther nething els i shode check. p.s. i no im a ****y speeler srry
passenger side leak was coming from under the front skid plate near radiator.coolent was coming out rilly fast and a lot at 1s
it was to dark for me to see when i poped the hood
Last edited by swartlkk; Jan 3, 2012 at 09:56 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond. Rules are Rules.
water from exhaust can be condensation.
intake manifold, it can leak coolant outside the engine, and it can burn some coolant.
find the leak fast, because if coolant is getting in the oil, it will ruin your bearings...
btw, im canadian, i speak french, and i can write better than you. please make an effort, this is no text messages.
93 s10 justin
Mar 5, 2010 04:09 PM
