leaking lots of coolent
Old Jan 3, 2012 | 08:33 AM
nick'sblazer42's Avatar
nick'sblazer42 is on a distinguished road
Default leaking lots of coolent
i cant find a bad hose the systum is bone dry right now and im at work so cant add water till lunch to see where leak is coming from and its my DD X-( puss its 27° out thining radeator is ther nething els i shode check. p.s. i no im a ****y speeler srry
Old Jan 3, 2012 | 08:47 AM
warthogdriver's Avatar
Do you have a rough idea where its at...pass side...driverside?
Heater core hoses on top of engine pass side.....waterpump?
Location and rate that your losing coolant would help out
Old Jan 3, 2012 | 09:49 AM
passenger side leak was coming from under the front skid plate near radiator.coolent was coming out rilly fast and a lot at 1s
it was to dark for me to see when i poped the hood
Last edited by swartlkk; Jan 3, 2012 at 09:56 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond. Rules are Rules.
Old Jan 3, 2012 | 11:12 AM
xgiovannix12's Avatar
sounds like the water pump you might wanna remove the plate to check it
Old Jan 3, 2012 | 11:14 AM
its doesent have a ruff idel but i did see water coming from the muffler :-(
Old Jan 3, 2012 | 04:22 PM
do u guys think it could be a intack manifold?!?
Old Jan 3, 2012 | 06:12 PM
98blazin's Avatar
98blazin is on a distinguished road
water from exhaust can be condensation.
intake manifold, it can leak coolant outside the engine, and it can burn some coolant.
find the leak fast, because if coolant is getting in the oil, it will ruin your bearings...
btw, im canadian, i speak french, and i can write better than you. please make an effort, this is no text messages.
Old Jan 4, 2012 | 05:40 AM
well im not driving it now its going to be towed to a teck for work. and it was way more then just condensation coming out
rturner14
Jun 21, 2010 03:42 PM
93 s10 justin
Mar 5, 2010 04:09 PM
Deezy Steez
Nov 3, 2009 06:03 PM
eelding
Jun 23, 2007 06:15 PM
eelding
May 10, 2007 09:54 PM
