Locate a Detent TV Cable
Old Feb 20, 2009 | 10:25 PM
rdhack's Avatar
rdhack is an unknown quantity at this point
Default Locate a Detent TV Cable
I have had a serious problem locating a TV/Detent/Kick down cable for my 1991 4.3L 700r t10 Blazer. Got one from Rock Auto only to discover that after talking to their supplier ATP that ATP has nothing that will work. (The diameter of the shaft going into the transmission is too small on all their listings). The tech at ATP gave me a number for Lokar, who could make one from the original...but that would take forever.
Could someone give a list of suppliers I could contact? It would be greatly appreciated.
Old Feb 21, 2009 | 03:10 PM
Hanr3's Avatar
Default RE: Locate a Detent TV Cable
Autozone would be my first stop.
If they don't have it, this place will.
http://www.transmissioncenter.net/pe...automotive.htm
Old Feb 21, 2009 | 04:01 PM
rdhack's Avatar
Well I Kentucky Hillybillyengineered a cable from part of the old, part of one from one of my excess truck parts, and the new one from Rock Auto. Basically used 1/4" compression coupling and cut two cables spicing them together, then using the original wireline with the new T connection from Rock Auto cable. T connection had to be drilled out for a larger wire cable and Throttle Body had to be drilled out to hold the new larger T connector.
Glad that's over!
Old Feb 21, 2009 | 04:23 PM
You must have forgotten about your other thread on this exact topic.
*Thread Closed*
MoneyPit99BlazerLT
Jan 21, 2014 10:40 PM
gdhurst
Oct 29, 2013 05:31 PM
TexasRider
Jun 11, 2013 11:25 PM
Jimmy91
Jan 16, 2012 09:08 AM
rdhack
Feb 17, 2009 08:46 PM
