loss of power
Old Mar 29, 2011 | 04:19 PM
jasonwilde's Avatar
jasonwilde is on a distinguished road
Default loss of power
I have a 1996 blazer 4x4 with a 4.3l engine. It will sit and idle fine but when I put it in gear it doesn't have very much power. I have changed all 4 o2 sensors, mass airflow sensor, spark plugs and wires, distributor, rotor, camshaft positioning sensor,coolant temp. sensor, map sensor, fuel filter and i took the catalytic converter off but I still have no power. Does anyone have any suggestions?
Old Mar 30, 2011 | 02:33 PM
kmulholl's Avatar
kmulholl is on a distinguished road
i'd check compression on all six cylinders. the middle plug on drivers side is a real bear. get a spark plug wrench , it has a t-handle and swivel real close to the socket. . you turn it like 1/6 turn, pull it off, move it and then another 1/6 th turn, and so on. also , use a plug wire puller, those boots are in there pretty deep you'll get it. you can borrow a tester at auto-zone. also, check for stored codes , auto-zone again can read them for free. also, note the condition of the plugs, keep track of which cylinder they come out of.
bryanmine
May 19, 2011 11:27 AM
kerander
Jan 18, 2007 01:21 PM
mdhokenson
Apr 19, 2006 07:21 PM
paul06
Jan 17, 2006 04:54 PM
the wood
Oct 29, 2005 12:48 PM
