Lost power
Old Feb 7, 2019 | 10:42 AM
la_blazer's Avatar
la_blazer is on a distinguished road
Default Lost power
My Chevy Blazer 2000 doesn’t have strength when I put it in D. If I change it to third, second, first or R it does run well. Could someone give me an idea of what this problem could be?
Old Feb 7, 2019 | 11:05 AM
cleburne red's Avatar
By not have strength, what do you mean? Does it go into gear at all when you select D? If it drives and shifts fine in other gears, maybe your shift cable has stretched? I had that problem, but mine never would go into park.
Old Feb 7, 2019 | 12:02 PM
go chevy's Avatar
Neutral safety switch cable I think???
Old Feb 7, 2019 | 05:30 PM
la_blazer's Avatar
when it is in D it does not run, only when I change it to another gear.
Old Feb 7, 2019 | 06:50 PM
Transman304's Avatar
What happens once you get moving from another gear and then put it in drive? Does it stop moving or continue to work until you stop again?
Old Feb 11, 2019 | 10:13 AM
la_blazer's Avatar
Unhappy
Originally Posted by Transman304
What happens once you get moving from another gear and then put it in a drive? Does it stop moving or continue to work until you stop again?
If I switch to 2, 3 or R it continues to work very well. If I switch it back to D and press the pedal no power.
Old Feb 11, 2019 | 03:55 PM
Have someone in the truck moving the shifter from park down through the gears, while you lay underneath and watch the shift linkage. Sounds like it's not going into drive and getting lost in some neutral position
Caleb Lav
Oct 29, 2018 09:40 AM
Dkarll88
Oct 15, 2018 06:27 PM
TheRandom1
Jan 4, 2012 10:40 PM
newgem
Mar 2, 2009 09:30 AM
nevwyn
Nov 11, 2007 06:39 PM
