Main and Rod Bearings instruction picture.
Old Oct 31, 2010 | 07:22 PM
chevygonzalez's Avatar
chevygonzalez is on a distinguished road
Default Main and Rod Bearings instruction picture.
I'm in the process of replacing a crankshaft on a 99 blazer 4.3. I have the new crank and matching bearings. I have the torgue spec . Can't find a book with specific instruction as to position of bearings. Any help would be speediely appreciated.
Old Oct 31, 2010 | 08:11 PM
franklin's Avatar
franklin is on a distinguished road
Connecting Rod Nut First Pass 20 ft.lb Final Pass 70 deg. Connecting Rod Bearing Clearance (Production) 0.0015 - 0.0031 inConnecting Rod Bearing Clearance (Service) 0.0010 - 0.0030 inConnecting Rod Side Clearance 0.006 - 0.017 in
Crankshaft Bearing Cap Bolt (Preferred Method) First Pass 15 ft.lbFinal Pass 73 deg. Crankshaft Bearing Cap Bolt (Optional Strategy) 77 ft.lbCrankshaft Bearing Clearance (Journal #1 - Production) 0.0008 - 0.0020 inCrankshaft Bearing Clearance (Journal #2,#3, and #4 - Production) 0.0011 - 0.0023 inCrankshaft Bearing Clearance (Journal #1 - Service) 0.0010 - 0.0020 inCrankshaft Bearing Clearance (Journal #1, #2, #3, and #4 - Service) 0.0010 - 0.0250 inCrankshaft End Play 0.002 - 0.008 inCrankshaft Journal Diameter (Journal #1) 2.4488 - 2.4495 inCrankshaft Journal Diameter (Journal #2 and #3) 2.4485 - 2.4494 inCrankshaft Journal Diameter Journal #4 2.4480 - 2.4489 inCrankshaft Journal Out Of Round Production 0.0002 in
Note: MaximumService 0.0010 in
Note: MaximumCrankshaft Journal Taper Production 0.0003 in
Note: MaximumCrankshaft Runout 0.0010 in
Note: MaximumConnecting Rod Journal Diameter 2.2487 - 2.2497 inConnecting Rod Journal Taper Production 0.00030 in
Note: MaximumConnecting Rod Journal Out-of-Round Production 0.0002 in
Note: Maximum
ceanern
Jun 25, 2012 12:44 PM
streblo
Jan 25, 2011 09:28 AM
caverwv
May 18, 2010 11:30 AM
bigdaddykane93
Aug 3, 2009 03:03 PM
apbtdlk
May 26, 2008 11:43 AM
