Metal Gas tank Removal
Old Sep 25, 2021 | 12:11 PM
pimpin's Avatar
pimpin is on a distinguished road
Exclamation Metal Gas tank Removal
Trying to remove my metal gas tank from my 1998 4x4 blazer, ITS TOTALLY STUCK IN THERE
ok i removed..
filler neck both rubber hoses in rear of tank
two bolts on side where the emergency brake cable is
3 small bolts in the filler tube
two straps, one nut and one bolt
all wires going to pump
all hoses going to pump
hose going to front of tank
fuel filter
Whats Left, it rocks, and is lower now in the rear
but after a few inches stuck like hell, front wont drop at all because part of tank goes over crossmember
and there is a stupid plastic shroud there.
tank wont move toward rear to release from crossmember
What else can be removed???????????
Please help
Does it have to do with 41 44 or 47??
On the diagram I have dislodged 25 &26, 35 and 33 are also removed.
Old Sep 25, 2021 | 07:11 PM
pimpin's Avatar
Ill try to see the side by 40 tomorrow I have no lift so its very hard.
Old Sep 25, 2021 | 10:45 PM
pimpin's Avatar
maybe there are bolts on the floor in the truck or something holding on the top part of the bracket, its gotta be something like that
Old Sep 26, 2021 | 08:42 AM
Removing the straps 32 and 34 should let it drop down...
Old Sep 26, 2021 | 10:54 AM
pimpin's Avatar
thanks DonL, I think I figured it out, the leaf spring bolts are stopping it from falling, going to be hard to get it done now.
Old Sep 26, 2021 | 11:03 AM
Thats a pain! Good luck!
cal_redwood
Apr 21, 2014 04:04 PM
cnmcconnell
May 17, 2009 05:14 PM
guywm25
Apr 25, 2008 08:29 PM
FImports
Dec 4, 2006 04:58 PM
jaykeMURD
Jul 12, 2006 10:17 PM
