Misfire or shudder?
Old Mar 21, 2017 | 07:29 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default Misfire or shudder?
Hello, 04 Blazer, 80k miles. It's been doing this for a while, but is becoming more frequent. What happens, is that while in 4th/torque converter lockup, it feels like 4th is shuddering, like locking/unlocking. It only does this going up hills, either at 45 or 70. If it is a long uphill, the check engine light will start flashing, signaling a multiple misfire. I'm not sure if this is a torque converter lockup shudder, or a misfire. I have done plugs, wires, cap, rotor, and fuel pump last spring. If it is a misfire, why is it only under load/going up hills? Looking for insight, help is appreciated, thanks!!
Old Mar 21, 2017 | 08:55 PM
Strangerock's Avatar
Strangerock is on a distinguished road
Does it log a misfire code as well as the light ...do you have access to a real time scanner to see if there is misfires ?
Old Mar 22, 2017 | 01:05 AM
newguy's Avatar
Sounds like an arcing spark plug wire
Old Mar 22, 2017 | 05:10 AM
The light stops flashing shortly after getting over the hill and stays off. I don't have a real time scanner to check.
If it's an arcing plug wire, why is it only doing it up hills?
Old Mar 22, 2017 | 06:17 AM
more load gong up the hill.
Old Mar 22, 2017 | 12:33 PM
newguy's Avatar
Sign of bad spark wires, check to see if they are on fully. Cheap wires will also do this. Is there any skip when idling?. Open hood at night, take out Underwood light. Look for arcing from wire to metal.
Old Mar 22, 2017 | 07:23 PM
Alright, I'll have to check that. Yes, it has a slight misfire while idling now, that just started. Scanned for codes and it has p0301 stored but the CEL isn't on. I'll check out cyl 1 plug and wire and at the cap.
Old Mar 27, 2017 | 03:11 PM
Thanks for the help guys, it was the wires, was arcing onto the exhaust manifold. Much better now!!
Old Mar 27, 2017 | 06:18 PM
newguy's Avatar
Good news, thanks for telling us
noruckus
Apr 28, 2011 06:19 PM
seedsorter
Apr 3, 2009 03:59 PM
Trogger
Jul 31, 2007 09:22 AM
magtec
Jan 21, 2007 06:09 AM
tammikm
Aug 18, 2006 11:07 PM
