Misfire Upon Acceleration and Cruise Control
Old Dec 14, 2018 | 08:56 AM
TheZR2ThatCould's Avatar
TheZR2ThatCould is on a distinguished road
Default Misfire Upon Acceleration and Cruise Control
(2000 2-door 4x4 4.3) As the title says, when I accelerate, between gears I get a chugging, misfire kind of soft jolt and when I set my cruise control at above roughly 50 my rpm's bounce lightly and it makes that soft popping noise (I have a flow-master muffler so I can hear these noises through my exhaust). My gas mileage also appears to have dropped but it may be in my head. I have replaced my spark plugs but that is all I have done. I have read that I should replace my coil overs and/ or plug wires. Anyone have any ideas or can confirm these? ANY experience or ideas welcomed, and also I will reply when the issue is solved or someone comments (im not a ghost poster).
*NOTE: I have no issues or hear any noises upon idling.
Edit: I have multiple O2 sensor codes- B1S2 and B1S3 issues.
Old Mar 30, 2019 | 10:59 AM
9702BlazerStyle's Avatar
9702BlazerStyle is on a distinguished road
Are you getting any misfire codes? I just got mine figured out and it was a bad coil. Did almost the same thing as yours. After i changed my plugs (using the correct oem plugs, acdelco iridium), i also had to change a coil. You might have to change out a coil over or the plug wires, whichever your vehicle has. But first find out if there are any pending (unverfied) misfire codes to point at a specific cylinder. The way mine went, the light would blink but not stay on so i had to look up the codes its was throwing, but not storing. If that makes sense. I use a obd2 bluetooth tool with torque (lite) to find it. So you might have a bad coil/wire and not even know it.
Old Mar 30, 2019 | 11:42 AM
Strangerock's Avatar
Strangerock is on a distinguished road
Check fuel pressure to be certain , easy to check and eliminate as a problem. diagnostic before part replacement is the way trouble shooting should be done.
Old Mar 30, 2019 | 11:58 AM
Hopefully he fixed his problem from December...
Old Mar 30, 2019 | 11:52 PM
🤣😂😂 heres hoping. But if not, now he has other things to look at.
Old Apr 18, 2019 | 01:42 PM
Default The return...
Alright folks, sorry I forgot to update yall. I changed my ignition plug wire last time and that fixed it. But its been a few months and has returned with a vengance. I replaced both the ignition coil and wire. The only codes its throwing is o2 sensors. A lot of them. Bad heat circuts etc.. Any ideas?
Old Apr 18, 2019 | 03:33 PM
If you know how to, maybe clean your injectors...
Old Apr 18, 2019 | 03:37 PM
thanks for the reply, no I do not know how.. ill research some videos but if you have any pointers that would be greatly appreciated
Old Apr 19, 2019 | 11:38 AM
I have not done it myself, but my shop says it can be done... I usually add injector cleaner when I fill up from time to time...
Slim6969
Dec 9, 2016 08:18 AM
ChrisCampbell96
Feb 3, 2013 06:56 PM
sxa3310
Dec 29, 2011 06:42 PM
JohnnyALCATRAZ
Oct 31, 2011 06:53 AM
gmanuel
Dec 9, 2006 07:15 PM
