motor
Old Aug 2, 2010 | 11:34 PM
badboy's Avatar
badboy is on a distinguished road
Default motor
I need to know how to get the bolts out of the motor with the firewall in the way?
Old Aug 2, 2010 | 11:40 PM
Drop the back of the trans and get ~3' worth of extensions and a good wobble socket set.
Old Aug 2, 2010 | 11:45 PM
badboy's Avatar
When changeing motor. Do you need to pull motor transmission and transfer all together on 1998 4wd
Old Aug 2, 2010 | 11:53 PM
Not necessarily. It can be a challenge to get them out together without pulling the hood and radiator support.
Old Aug 2, 2010 | 11:59 PM
badboy's Avatar
the hoods off and raiator is out just trying to find the easiest way to get the motor out
Old Aug 3, 2010 | 12:12 AM
If you have an engine hoist that can lift up pretty high as well as an adjustable engine load leveler, it should all be able to come out together. I would still drop the transfer case off from underneath first. It all depends on how you want to do it. There are other threads out there where others have said how they have done it in the past.
LesMyer
38
Jan 9, 2020 11:45 AM
SWATPARAMEDIC
Jan 1, 2010 03:12 PM
rob1621
Feb 29, 2008 08:15 PM
02 Vortech
Engine & Internal
Mar 22, 2005 12:02 AM
pusher_sr
Mar 6, 2005 04:26 AM
