Motor medic motor flush
Old Feb 9, 2019 | 08:15 PM
Katlin Marie's Avatar
Katlin Marie is on a distinguished road
Default Motor medic motor flush
So I decided to use a motor flush I added it to my oil and I couldn't get the bolt out of the oil pan it was getting dark and cold and I needed to move the truck so I drove it to a friends about 2miles away and parked it for the night spent all day today trying to get the bolt out but still cant my question is will the motor flush cause damage sitting in it this long
Old Feb 9, 2019 | 09:27 PM
cleburne red's Avatar
Can't give you an answer about the motor flush, since I've never used them, and I think they're pretty much snake oil to begin with.
As far as your oil pan drain bolt, you spent all day trying to get it loose? Sounds like it might be cross threaded. Either way, I would have kept getting longer and longer cheater pipes until it came out. With enough leverage you can get any bolt out
Old Feb 10, 2019 | 10:52 AM
rriddle3's Avatar
From their website's FAQs:
Q: Is it safe for my engine?
A: The chemicals in Motor Flush are completely safe for all engines, as long as the application / use time does not exceed the specified time period of 5 minutes and other use directions are followed. It is designed to offer optimal cleaning while preserving lubricity of the oil to prevent wear during cleaning.
Q: Can I drive with Motor Flush in my engine?
A: No. Motor Flush is only to be used right before an oil change with the engine at idle. Never drive a vehicle until the old oil with Motor Flush is fully drained and new oil is added
Q: Can I leave it in over 5 minutes?
A: No. Due to the strength and effectiveness of the formula, longer application times (exceeding 5 minutes) could lead to engine damage.
Old Feb 10, 2019 | 12:29 PM
Damn, that doesn't sound good at all. If you absolutely can't get that drain plug off, might want to get one of those suction pumps and suck the oil out
Old Feb 11, 2019 | 12:24 PM
go chevy's Avatar
My thoughts exactly!!! What the heck is that stuff anyway? Some kind of acid thingy eating stuff away like a bad virus lol! Righty tighty, lefty loosey..... Whatever it takes, get that stuff out of there...
slcblazer
Jun 2, 2013 12:39 AM
lionel2
Mar 14, 2013 05:09 PM
April
Jun 4, 2011 06:04 PM
hissingfetus
May 22, 2010 09:08 PM
WhiteNoiz
Jul 31, 2009 10:55 PM
