My gear shifter came completly off!!!
Old Feb 12, 2009 | 08:43 AM
lionel2's Avatar
lionel2 is an unknown quantity at this point
Default My gear shifter came completly off!!!
I have a 2002 chevy Trailblazer LS with an automatic transmission. The gear shifter is on the center consol, between the 2 seats. When I went to put car into reverse the whole **** or gear shifter came completly off. What is wrong and how do I fix this?? It is still loose and will come off again if I pulled up on it. Seems like something might have broke. Any help will do. Any part names or advice please. Thanks.
Old Feb 12, 2009 | 09:08 AM
WolfPack's Avatar
Default RE: My gear shifter came completly off!!!
Most floor shifted vehicles use a small screw to hold the gear shift on. I have not been in a blazer with the floor shift in a while so I cant say for sure..but...just look on the front, below where your fingers would go.
Old Feb 12, 2009 | 11:09 AM
lionel2's Avatar
This is a 4.2L inline 6 trailblazer from 2002. You might have it mixed up with a 4.3L V6 that looks like an S10 blazer. The newer body style. I will still look for that screw or if it is missing.
Old Feb 12, 2009 | 12:34 PM
lionel2's Avatar
Okay, I fixed it!! They was a screw by the button that you push with your thumb. It was almost comming out, so I tightened it all the way. I am good now. Thanks.
Old Feb 12, 2009 | 12:36 PM
Glad you got it fixed. Regardless of the vehicle, as Jason stated, most have a small screw which holds on the shift lever.
matthewp
Apr 4, 2021 09:16 PM
88s10Blazer
Sep 11, 2013 02:41 PM
jasedude
Nov 24, 2010 04:03 PM
96ProjectHighLife
Suspension Tech
May 26, 2010 12:42 AM
rbcar1
Dec 13, 2009 10:20 AM
