dist install troubles
Old Feb 11, 2009 | 12:48 PM
stevensdad's Avatar
stevensdad is an unknown quantity at this point
Default dist install troubles
Replaced intake manifold gaskets on 1998 s10 blazer, now having a real tough time getting the distributor back in(4.3l) , set tdc for #1 cyl and lined up marks on dist shaft but always seems to a tooth off from pointing at the dist casting mark(#6). Any help is great.
Thanks
Old Feb 12, 2009 | 01:00 PM
jeepmudbogger's Avatar
jeepmudbogger is an unknown quantity at this point
Default RE: dist install troubles
did you turn the oil pump shaft in the bottom of the hole? that may be keeping you from being able to get it in the proper place
Nutty 99 Blazer
Dec 11, 2013 06:00 AM
Radio_Flyer
Feb 11, 2011 06:03 AM
esserville
Apr 16, 2010 03:39 PM
scott96
May 26, 2008 09:21 PM
fnirish
Oct 24, 2006 02:02 AM
