Mysterious hose....to me lol
Well the little ball is a vacuum collector ball it should be mounted on the bottom side of the hood above the master cylinder, it must have broken off
*EDIT*
Ok so that big black circle thing behind the brake master cylinder is the brake booster I suppose? The hose in question(not connected) is running right over that S1 sticker on it. then it goes back behind the motor to that little ball thing which is a vacuum collector?
Looks like a mess... LOL
I am still trying to figure out what that actuator connects to. Still looks like a cruise control actuator to me. The cable that runs out the end of it towards the firewall (circled in red again on the attached image below) would run around the back of the engine up to the throttle body. Try pulling on the cable at the actuator to see if it moves the throttle.
As far as where that vacuum line goes... Does everything inside the truck, hvac wise, work properly?
Yeah lol its a very dirty mess. But to be honest I have never had more fun trying to figure out the issues im having and working on this then I have with any other car
Circled in red. Looks like that cable you were wondering about does go to the throttle body
So you do have cruise control! LOL
Anyway, where does the large vacuum hose off of the cruise control actuator go to? It looks as though it is just taped up near the master cylinder...
oh and about the hvac... the control for the heating on ac on the dash isnt even connected. When I got the blazer it was just sitting in the glove box rofl
I had that hooked up a few hours ago and when I turned it on there was nothing coming out of the vents in the car, but there was a strange slight whistle noise coming from behind the control unit... and under the hood this thing would spin then stop, spin then stop etc etc
yeah that large hose goes back under the master cylinder out of site and is really tight so not much pull on it.
lol as for cruise control... I have no way of setting it inside. I think I recall the person I bought it from saying the dash computer? was replaced. maybe the controls use to be in the steering wheel and that was replaced too? haha man this is going to get confusing
The spinny thing you have circled is for the A/C.
ok and that spinning for maybe 2 seconds and then stopping and then spinning again a second later for 2 seconds means what? Im not getting anything from the vents inside the vehicle. I just get a slight whistle noise from behind the ac control panel
well this should probably go in a different thread huh lol. Im still trying to find out what that disconnected hose that goes to the ball vacuum thing does
I think it means you are low on freon. So "if" the fan does blow some air your way it won't be cold.
86TransAm
14
12-13-2011 07:46 PM
treysanatomy
11-15-2009 09:00 AM
jaykeMURD
15
12-26-2008 01:23 PM
