New engine and transmisson for 4dr, 95 lt blazer
Old Jun 5, 2011 | 06:10 AM
Rasta Chow's Avatar
Rasta Chow is on a distinguished road
Default New engine and transmisson for 4dr, 95 lt blazer
The chevy blazer still looks nice and it's 4 wheel drive. How much it should cost? My dad said to rebuild the engine but i don't know what to do.
Old Jun 5, 2011 | 11:11 AM
Oystein's Avatar
Oystein is on a distinguished road
If it's bad anyway, swap it for a V8. Head over to a scrapyard and get a 350 cheaply. That's what I would do.
Old Jun 5, 2011 | 11:58 AM
TheRandom1's Avatar
If you're having a shop do it, expect 2K+
Old Jun 5, 2011 | 05:21 PM
wrenchturner3529's Avatar
wrenchturner3529 is on a distinguished road
Motor: I would go with a new crate motor. The cost would probably be about the same as a rebuild, dependent upon what has to be replaced.
Old Jun 6, 2011 | 08:03 AM
oktain's Avatar
Unless the part that failed took other parts out then it would be cheaper to rebuild.
A 350 swap is not as simple as you make it sound Oystein, you need conversion mounts, headers, wiring harness, PCM, etc.
*Moved to Engine & Transmission*
Note that the New Member Area is meant only for introductions and not technical questions.
bobby099
Mar 8, 2012 12:43 PM
Phyrstorm
Jul 9, 2010 01:03 AM
99 Blazer 4 door
Performance & Brainstorming
Aug 29, 2008 10:46 AM
SoDakBlazer
Aug 5, 2006 06:21 PM
BlaZeR FXB1581
Engine & Internal
Jan 27, 2006 07:45 PM
