radiator fluid is rust colored need hlp
Old May 23, 2011 | 12:23 PM
paul94blazer4x4's Avatar
paul94blazer4x4 is on a distinguished road
Default radiator fluid is rust colored need hlp
i have a 94 s10 blazer 4.3 vortex w on the vin my water pump went out and when i replaced it my fluid was rust colored and i flushed it all out till clear put all back together and re filled well checked it today and its back to rust colored again what do i need to do to fix this i have no clue at all i flused everything i could and still rust colored?
Old May 23, 2011 | 12:57 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
When I first got my blazer it had been sitting a couple of years. I literally flushed it something like 6 times before it was all cleaned out, I also replaced the entire cooling system that way the block was the only thing that could have that crap in it. It was a long process but definitely worth it.
Old May 23, 2011 | 05:21 PM
chris015's Avatar
yeaaaaaa its a mixture of 20 years and dexcool etc that causes it. You can get it all cleaned out,but it will take forever. Took me 11 flushes and mines still a little discolored.
Drain the rad,remove the thermostat and run your hosepipe through it and let it run till it runs clear,then do the same with the rad. Even then it'll somehow turn brown again..do this as many times as you want until you feel satisfied.
Old May 24, 2011 | 09:45 AM
You need to get all of that junk out of there. That typically requires the removal of the drain plugs on the sides of the block to get the water jackets in the block completely drained and flushed clean.
Wasn't '95 the first year for Dexcool use in these trucks?
Old Jun 6, 2011 | 02:57 AM
darknight's Avatar
darknight is on a distinguished road
You might need to check the cap for ur rad... da rubber seal on mine was broken so da coolant was eating at it and Dats where da rust came frm...
Old Jun 6, 2011 | 10:26 AM
chris015's Avatar
Old Jun 6, 2011 | 11:45 AM
mxpxpunkrock1987's Avatar
mxpxpunkrock1987 is on a distinguished road
after u get it clean with water buy clr dump the can and add water and run 4 30 mins and let cool for 30 then drain then flush with water that should do the trick did it with mine runs cleans and a bunch of rust should come out
koreiryuu
Mar 20, 2014 02:01 PM
autojunkie95
Sep 21, 2011 08:08 AM
The_Beast
Apr 21, 2010 08:38 PM
agibson94
Jan 12, 2009 09:37 PM
mykro1dj
Tires and Wheels
Mar 30, 2008 09:38 AM
