New here, Needhelp 1988 s10 engine
Old Apr 14, 2009 | 09:42 PM
beenjay's Avatar
beenjay is on a distinguished road
Default New here, Needhelp 1988 s10 engine
i have a 1988 chevy s10 blazer 4x4 4.3 l v6, i have a knocking sound coming from the engine which only has 30,000 miles since rebuild. vehicle overheated and blew a head gasket about 6 months ago which i replaced by pulling both heads, machined them and rebuilt them. Therefore I did a complete head job. vehicle ran fine for about 1500 miles then all of a sudden started knocking in the engine. Sounds like to me its in cam shaft area and not low end, did not replace lifters with head job. Runs and drives great if i retard the timing the noice starts to go away, but of course vehicle runs like a dog then. I was told possible knock sensor...any advise would be very appreciated. thanks Jason
Old Apr 16, 2009 | 02:36 PM
A "knock" is typically a bottom end problem while a "tap" will typically be a valve train issue.
Did you get coolant in your oil? If so, how long did it run like this? You may have washed a bearing and damaged it...
djramsay
Jan 11, 2010 12:42 PM
jimminiquick
Aug 3, 2009 12:35 PM
djramsay
Jun 17, 2009 04:37 PM
djramsay
Apr 10, 2009 09:30 PM
pman332
Mar 14, 2008 12:45 PM
