Cant Get My 1988 s10 Blazer in 4x4
Old Nov 15, 2009 | 03:50 PM
djramsay's Avatar
djramsay is on a distinguished road
Default Cant Get My 1988 s10 Blazer in 4x4
i was out this weekend and it would not go in to 4x4 low or high it would go throw all of them but it wont engage it to 4x4 high or low
Old Nov 15, 2009 | 04:43 PM
So your front axle did not engage, but the transfer case was able to engage in both HI & LO? If that is the case, it could be any one of the following:
  • frozen front diff engagement cable
  • bad front diff engagement actuator
  • vacuum line problem between the engine and transfer case and/or between the transfer case and the front diff engagement actuator
  • bad vacuum switch on the transfer case
Old Nov 15, 2009 | 06:55 PM
cmh_20's Avatar
cmh_20 is on a distinguished road
ACTUATOR start with that there known to go bad on the s blazers it did it to me so i bought an aftermarket posi-lok system which is cable engaged not vaccum,you can then take your vaccum acuator off and bypass it with the posi-lok worth everybit of 170 dollars in my opinion
Old Nov 20, 2009 | 11:01 AM
shawndazey's Avatar
shawndazey is an unknown quantity at this point
vaccum vaccum vaccum they suck suck suck. go with posi-lok system!
Old Nov 20, 2009 | 08:16 PM
abig84's Avatar
yep. every one with a s10 eventually had to deal with this. had a 85 where a pair of vise grips worked perfect for locking the front axle
Old Nov 25, 2009 | 01:15 AM
pud_009's Avatar
pud_009 is on a distinguished road
Sorry for piggybacking on this thread, but I'm also having similar problems and I was looking for some help.
My '93 S10 Blazer 4x4 is wrecked. I replaced the vacuum actuator because it was ripped, but that didn't fix it. I just replaced my electronic 4x4 switch, and that didn't fix it.
I know I still have power to my switch, but the only time pressing the switch will do anything is when my Blazer is in neutral. The 4HI and the 4LO indicator lights will blink on and off when I press the switch when my Blazer is in neutral, and I hear a clicking noise from what seems to be the right side of my Blazer, but that's it. The blinking lights on the switch turn off soon after and nothing else happens, no 4x4 at all. When I'm in any other gear pressing the switch does absolutely nothing.
Any ideas? 4x4 is a little beyond my mechanical abilities so I'm looking for any and all help I can get. I'm just tired of Canadian winters with no 4x4 haha.
Thanks
Old Jan 11, 2010 | 12:42 PM
92blazerredneck's Avatar
92blazerredneck is on a distinguished road
i got the same problem with my 92 blazer tahoe. it will light up but it wont engage. y?????? thx
mitch.dail
Sep 13, 2014 08:20 PM
Eagle Blazer
Dec 19, 2010 04:26 PM
theboyewonder
Dec 8, 2010 08:49 PM
K.N.I.G.H.T
Mar 28, 2010 06:42 PM
n.kognitoh
Sep 22, 2007 07:15 PM
