new to me 93 cpi blazer
Old Dec 10, 2023 | 05:26 AM
cartercarbaficionado's Avatar
cartercarbaficionado is on a distinguished road
Default new to me 93 cpi blazer
got a new s10 with a no spark condition, honestly thought it would be easy but it's sparking from the coil...sometimes? but nowhere else and even direct from coil it has to crank for 5 seconds to start sparking
Old Dec 10, 2023 | 04:31 PM
GeorgeLG's Avatar
Do you mean sparking from the coil body or you pulled the lead and it is sparking to ground?
George
Old Dec 10, 2023 | 04:34 PM
George
coil lead to ground, purple spark but wont start the engine and timing is correct, so I'm grabbing a new distributor since the pickup is more expensive than a used entire dist
Old Dec 10, 2023 | 04:37 PM
GeorgeLG's Avatar
George
Old Dec 10, 2023 | 04:39 PM
10-4
George
will get back once i install the new one and time the engine
Old Dec 11, 2023 | 04:22 PM
10-4
George
some pops while idling so I need to address that but it was the pickup being faulty intermittently
Old Dec 11, 2023 | 05:06 PM
GeorgeLG's Avatar
So your good or still need help?
George
Old Dec 11, 2023 | 06:50 PM
George
its running and running mostly ok, some help would be nice though since it's cranking for a few seconds before starting
File Type: mov
Old Dec 11, 2023 | 07:03 PM
GeorgeLG's Avatar
Do a fuel pressure leak down test and pull one plug wire and look for spark during the initial crank no start condition.
George
Old Dec 11, 2023 | 07:06 PM
George
no it starts its just cranking for 5 seconds before kicking over and runs a bit weird at idle
