this is a new one on me.
Old Mar 28, 2013 | 08:17 AM
piermechanic38365's Avatar
piermechanic38365 is on a distinguished road
Exclamation this is a new one on me.
traded for a 97 4wd blazer. the thing has a miss at idle and a light load. put a load on it( hard acceleration or pulling a hill) the thing doesnt miss a beat. i noticed in the after noon, it has the same issue but you can get the engine to temp and shut it off. then a few minutes later crank it and itll be fine. its throwing me for a loop. i believe itll be a module but im not sure. finances are extremely tight so i really dont want to throw a bunch of money at this thing...... thanks for any ideas......
Old Mar 29, 2013 | 06:46 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
First check the spark plugs.
second, do a fuel pressure test and leakdown. My 94 acted like this when the fuel pressure regulator started leaking. The extra fuel leaks into the cylinders, at idle and low rpm it is flooding it, but at higher speed it doesnt matter as much.
Old Mar 29, 2013 | 07:14 PM
newguy's Avatar
Things expand and get a better fit when hot
Old Mar 30, 2013 | 12:30 AM
Not the regulator. If it was leaking would be cleaner under plenum. Im thinking its going to be the ignition module. I have one in the mail as well as a dist. and coil. I checked to see if egr was locked up as well. Cleaned it but it was fine. Its not really rpm related. Its a load based issue. I can put it ingear and itll be skipping around. When i start brake torquing it, the engine smooths out and has plenty of power. It not throwing any codes........
Old Apr 8, 2013 | 08:16 PM
It was a faulty hall effects sensor under the rotor button.
Old Apr 9, 2013 | 04:29 AM
newguy's Avatar
Learn something new everyday, good for you
cjdavidson10
Mar 29, 2013 11:22 PM
97Beater4WD
Mar 24, 2012 03:46 PM
roadkill
May 15, 2010 07:19 PM
deerboy
Tires and Wheels
Dec 16, 2009 04:33 PM
error_401
Nov 13, 2007 07:55 PM
