"new" trans.... new code
Old Aug 20, 2011 | 04:38 PM
MonkeyGein's Avatar
MonkeyGein is on a distinguished road
Default "new" trans.... new code
got a used trans put in my 98 and now i'm throwin the P1870 code and all the hard shift goodies too.. now i have internetted before so i did already look it up and got a couple links below. does the internet here concur with what links are saying?
https://blazerforum.com/forum/engine...lipping-19143/
1998 Blazer Transmission Problem Problem Diagnosis - Car Questions, Answers, and Discussion
i also read on here FYI 4L60E common problems / failures | GM Truck Headquarters that the O2s and trans are on the same circut or something. i'm getting an O2 code too. i think "bank 1 sensor 3". could the trans code be related?
while i'm here, which one is bank 1 sensor 3? i had a stuck plug when i was removing the trans and just pulled the male ends out of the connector then out it back later. but there was two brow wire and not sure if it mattered where they went.
SOOOOO>>>> back to the trannys if it is the TCC do i need this kit here? TransGo Shift Kits 4L60E & 4L65E 1993-2006 (will not work on Hybrid) | Valve body kits | Bulkpart transmission parts
Difficulty?
Old Aug 22, 2011 | 12:19 PM
MonkeyGein's Avatar
anyone wanna weigh in?
Old Aug 23, 2011 | 05:30 PM
MonkeyGein's Avatar
ir could it e the solenoids inside the pan?
mercdod
May 15, 2014 08:56 PM
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
