No heat & over heat unless RPM's are increased
Old Dec 15, 2009 | 08:09 PM
mcaanda's Avatar
mcaanda is an unknown quantity at this point
Arrow No heat & over heat unless RPM's are increased
As the title states, at an idle the rig will start to climb up on the temp gauge but when you increase the RPM you hit the accelerator the temp will come down.
This started as we were sitting at a light, and I was like - you feel the cold air coming from the vents? As I noticed this, at the same time I was watching the temp starting to climb until I hit the gas - which at the same time hot air started to and did come back to the vents.
Happened multiple times while we were at the light, of course stuck in traffic and continued till I got it back to the house to which I stuffed 'er back into the garage and am planning on how to get started with the repair plan.
My thought is that the water pump snipped the shaft but is catching enough to get the water though the system when the RPM is off idle. If its the case, I think that might be a good time to swap out the T-Stat as well.
Anybody else have some thoughts on this one?
Old Dec 15, 2009 | 08:31 PM
DrEaMsTeVe's Avatar
DrEaMsTeVe is on a distinguished road
2nd on the water pump. The impeller is probably shot. That would explain why your heat only comes when you rev the engine. Would also explain the overheating at idle.
Digitized
Jan 12, 2014 12:07 PM
sy24
Mar 9, 2011 09:23 PM
burning_soul07
Feb 5, 2011 11:10 PM
95ls2door
21
Jun 17, 2010 03:02 PM
xxx6thirty6
Sep 7, 2007 06:18 PM
