NO REVERSE Help
The TH350 or 700R4 that's in it, is probably losing the pump or the sun gear is either cracked or broken...
You are gonna spend around $1200 to $1800 for a transmission shop to properly go through the tranny.
If the blazer is in decent shape, you will end up with a pretty nice K5... I would not hesitate to invest in a vehicle like that!
Looks like it's worth $700 to me but you will have to see it in person to be sure. Check for things like serious rust along the bottom of the body panels, fenders, doors and tailgate. Also see if the frame is cracked around/behind the steering box. Either way... still looks like it's worth $700 to me.
bigt61
May 29, 2007 01:56 PM
