No start
Old Jan 12, 2017 | 08:42 AM
LesMyer's Avatar
I'm sorry but you have not done testing that will support even one of your conclusions.
Return to post #2 - test and report results. There are two pressure tests and two leakdown tests to do if it fires from carb cleaner. Read and understand the sticky at the top of the second gen forum.
Timing is non-adjustable and is set by the PCM. However if you have had the distributor out, then you could have dropped it back in with the rotor pointing to the wrong place. Tell me you haven't had the distributor out.
Old Jan 13, 2017 | 08:59 AM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Yes, it was the distributor. I checked right after I did the injector. When I meant timing I meant either the chain slipped or the distributor slipped.
Old Jan 13, 2017 | 01:43 PM
newguy's Avatar
Well dont change the chain until you reinstall the dist. the right way
Old Jan 16, 2017 | 11:14 AM
Yes I got it installed and it is running fine now. Though I have come across another problems. Shortly after having it running it again the SES light came on and gave codes P0172 and P0175; fuel system too rich on both banks. Is this due to my pulling off the plenum and possibly missing a vacuum line or unseated gasket or would it be something fuel related... again?
Old Jan 16, 2017 | 03:34 PM
95teal4x4's Avatar
95teal4x4 is on a distinguished road
mod please delete this post. Problem was already fixed. thanks
Last edited by 95teal4x4; Jan 16, 2017 at 03:36 PM. Reason: Problem was already fixed
ejxjohnson
Sep 10, 2010 08:21 PM
blazerJim1701
Jul 26, 2009 09:18 PM
Larhatch60y
Nov 8, 2007 01:05 AM
actionpaintball
Jul 14, 2006 07:53 PM
