No start. Fuel pump not priming.
Old May 2, 2016 | 07:19 PM
xxgrizzlybearxx's Avatar
xxgrizzlybearxx is on a distinguished road
Default No start. Fuel pump not priming.
Hello All...
Recently I ran into an issue while driving, the blaz just died. Wouldn't start back up. Pushed it to the side and saw the ecmb fuse was blown, ok cool. Tossed a new one in and the pump won't prime.
Checked the relay and pin 87 has some pretty black on it like a short. so I replaced the relay.
Yes the relay clicks for those two seconds the key is in the on position.
SO.. I know I'm missing something here. If I directly connect 12v to the pump where the grey/black wires meet it will run, I ahve 12v to the relay. I've checked grouunds... but no prime.
SO when I bridged pins 30 and 87 on the panel to force 12 to the pump still nada...
with a multimeter I ONLY get about 2.5-3.5 volts to the larger grey wire to the pump (now this is the same voltage if I run the ground to the black on the connector, the ground on the rear crosmember OR direct to the battery.
I'm at a loss. PCM not sending 12v? I know I have 12 at the fuse panel when I'm using a wire jumper, but not entirely sure what could cause the drop. I have ready about the oil pressure sender but would that cause such a drop in voltage?
ses light is on when key is in the on position and no flashing lights to indicate its a passlock issue.
Please help gurus
gtmccormick
Nov 25, 2014 11:35 PM
chris015
Jun 8, 2012 12:37 PM
blrob5
Apr 27, 2010 03:13 PM
Brian_D
Apr 17, 2010 07:04 PM
tiso_us
14
Jan 21, 2009 02:03 PM
