no start when hot
Old May 10, 2010 | 05:52 PM
Bunkie606's Avatar
Bunkie606 is on a distinguished road
Default no start when hot
I have a 1994 blazer with vortec engine. Starts right up when cold but sometimes after it's hot it will not start until it cools down. Also sometimes stalls and will not start until it cools down. Please help! Thanks for any help!!!!
Old May 10, 2010 | 06:15 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
do you have any codes? any recent maintaince done? how is the oil pressure and oil condition?
Old May 10, 2010 | 08:12 PM
Remove the coil and ICM. Take them to an autoparts store that does electronics testing and have them tested.
Old May 10, 2010 | 08:59 PM
Bunkie606's Avatar
Where is the icm located? Thank you for your help !!!!
Old May 10, 2010 | 09:03 PM
The ICM is located in the base of the distributor. It's what the electrical connections plug into.
Bunkie606's Avatar
How do you get the codes? No recent maintaince done?The oil pressure and oil condition are good. The Blazer has 135,000 on it. The fuel pump,fuel relay and fuel filter were changed. Also new starter.
Old May 11, 2010 | 12:13 AM
TreasonAgainstCaesar's Avatar
TreasonAgainstCaesar is on a distinguished road
Is your check engine light on? If so, go to autozone and they will read the codes for free.
If the check engine light is not on, then no codes.
stevenhousden
Jul 6, 2014 05:56 PM
Mandrwj
Apr 10, 2011 07:32 PM
88_s10
Jan 15, 2011 05:04 PM
blazerJim1701
Jul 26, 2009 09:18 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
