No transmission
The purple wire at the starter solenoid comes from the neutral safety switch, (on the transmission) which only activates the solenoid/starter when the transmission is in neutral or park only. Applying battery voltage to the purple wire will activate the starter. On the driver side, near where the transmission shifter would be, there is a wire harness that would connect to the neutral safety switch, you'll find the purple wire there.
