NP 233 Transfer Case Rebuild...
Old Jun 21, 2022 | 06:33 PM
mojave.joe's Avatar
mojave.joe is on a distinguished road
Default NP 233 Transfer Case Rebuild...
I have a 1999 Blazer, 4x4, Auto, 169k and I burned out the 4L60E on a long uphill climb. The radiator was already a mess and I should have replaced it... lesson learned.
I will be rebuilding the transmission and even started a thread about it. I will have to pull the transfer case to get the 4L60E transmission out and am considering a doing a rebuild while its out. Has anyone else tackled this project? Does anyone have a .pdf of the rebuild manual?
Any special tools needed?
Bearing Kit Bearing Kit
Drive Chain
Thanks,
MJ
Old Jun 22, 2022 | 12:39 PM
Following!
Something you might consider from my experience burning out my 3/4 clutch pack by towing in overdrive is to add an extra supplemental transmission oil cooler and a transmission fluid temperature gauge. For the cooler, I just recently installed a Hayden 699 with an integrated thermal bypass valve. For the gauge I'm using an Ultra Gauge OBD reader.
BTW, what tires are you running? Did you do a suspension lift?
Old Jun 22, 2022 | 04:39 PM
I haven't rebuilt a NP233, but I did a 241 in a Jeep a couple of years ago, and there really wasn't much to it.
Old Jul 1, 2022 | 09:17 PM
JessenU's Avatar
JessenU is on a distinguished road
I recommend pulling the transfer case apart and replacing the chain and chain guides bare minimum. I just ruined my transfer case because the chain has too much slack in it. Lesson learned. I have some parts if you want. Brand new chain, bearing kit as well as all seals for t case. Let me know
mojave.joe
Jun 21, 2022 06:21 PM
Edvalle10
Jan 26, 2017 08:57 PM
No false Bravada
Oct 30, 2015 10:22 PM
Wldbill89
Mar 20, 2012 03:55 PM
86Blazer4x4
Aug 5, 2009 07:31 AM
