number 5 plug keeps misfiring
Old Dec 4, 2008 | 09:31 PM
delete242001's Avatar
delete242001 is an unknown quantity at this point
Default number 5 plug keeps misfiring
i have a 1997 chevy blazer 4.3 v6 past few weeks i get a check engin light when i start the car.so i check it and i get 2 codes a plug 5 misfire and a pending of the same code.so both codes the same .i changed plugs wires distrubator cap router button have not changed coil.if i drive it hard the code will evently go away and check engin light goes off.but when the check engin light comes on the car surges when u give it gas and after a few minuates it goes away.does anyone have any ideas what it could i cant figure this thing out.
Old Dec 5, 2008 | 12:30 AM
vin791's Avatar
vin791 is an unknown quantity at this point
Default RE: number 5 plug keeps misfiring
whats the fuel injection like on a 97? could be an injector.
Old Dec 5, 2008 | 09:38 AM
rriddle3's Avatar
Double check the wire connection at the distributor for that plug. They sometimes push up and lose contact.
Old Dec 7, 2008 | 07:49 PM
Blzr01Gy's Avatar
Blzr01Gy is an unknown quantity at this point
Sounds like something to do with your injector. The computer might be sensing a lack of fuel to cylinder 5 giving you a code. But when you get on it, it may be enough pressure or gas going through to get rid of the code. If the wires plugs rotor cap and coil are all good, it may be your injector.
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
ChevyHick01
Jun 18, 2011 06:27 AM
muleman
Sep 11, 2008 08:01 PM
boulonman
Mar 5, 2007 05:10 AM
