Odd Issue
Old Feb 3, 2009 | 03:12 PM
BlazerLove's Avatar
BlazerLove is an unknown quantity at this point
Default Odd Issue
This one has me kinda stumped. My blazer runs like a champ since I replaced the FPR. However, I have noticed a weird issue while driving. It only happens when I am coasting. I'll have my foot completely off the gas pedal while travelling down a gentle slope and every 3 or 4 seconds its almost like the transmission 'bumps?'. The best way I can describe it is it feels like it disengages for just a split second resulting in a slight 'bump' of deceleration. This only happens when coasting in overdrive.
Any ideas?
Old Feb 3, 2009 | 03:55 PM
corvette535's Avatar
corvette535 is an unknown quantity at this point
Default RE: Odd Issue
there seems to be a lot of that right now.... chances are its not the tranny. mines doing that same thing in overdrive under very very light throttle around 2k rpm.. next time it does this look to see if your rpms are jumping around or not...i'm starting with cleaning the egr and o2s then moving to test iginition coil and TPS this weekend to see if that clears it up.
Old Feb 3, 2009 | 05:10 PM
BlazerLove's Avatar
The RPM's do drop by about 500 when this 'disengage' occurs.
When I changed my FPR 3 weeks ago I cleaned the EGR and replaced the O2 sensor. Haven't ever replaced the coil..or TPS.. I will look into them. I didn't think that the CPI had a coil.
Old Feb 3, 2009 | 11:04 PM
BlazerLove's Avatar
Anybody else have any ideas? I'm worried that it may be the tranny.. and usually problems with the tranny only get worse, and that is the scary part-there is no way in hell i can afford a new one. I might as well do a hot and cold transmission fluid check tomorrow.
Old Jun 7, 2010 | 04:01 PM
mofiddle's Avatar
mofiddle is on a distinguished road
I have the same issue did you guys have any luck fixing it yet
00 4x4x4
Old Jun 7, 2010 | 09:31 PM
Denominator's Avatar
Denominator is on a distinguished road
Same problem here, you describe my problem better then me
I do NOT have the drop in RPM, but all the other things..
https://blazerforum.com/forum/engine-transmission-35/added-weight-one-person-jerking-back-44079/
Max0000
Sep 17, 2009 06:30 PM
iroczu
Aug 22, 2008 05:17 PM
LittleT
Jun 26, 2008 01:17 PM
drperry
Jan 16, 2007 10:19 AM
Gonzo7
Oct 4, 2006 04:22 AM
