Odd tranny noise
Old Feb 27, 2014 | 04:48 PM
newguy's Avatar
Default Odd tranny noise
98 blazer 4l60e drove it last night, every thing sounded fine. minus 3 overnight. Started it up this morning and there is a weird squeaking rubbing sound from the tranny. Shifts fine works normal. Goes away in gear 90%. goes away completely when warm. Fluid level good. checked the converter and thats tight. Stumped on this one
Just saw a post online saying that a clogged filter can cause a squealing pump. will do a filter and fluid change tomorrow
Old Feb 28, 2014 | 05:32 PM
newguy's Avatar
Changed the fluid and filter, still made the noise went away in a few minutes. Drove it for a half hour, shut it off and restarted it and had the noise again just till it was running. Thinking now its the starter. Almost an electrical and grinding sound when I turn it over. will pull it tomorrow and inspect it. Think its original.
Old Mar 1, 2014 | 11:48 AM
newguy's Avatar
Well, new starter, still makes the noise. I`m lost, almost sounds like the torque converter rubbing the case. As said above goes away when warmed up. Runs as normal. I give up for now, maybe it will fix itself LOL or break, then I`ll know what it is
Old Mar 3, 2014 | 02:29 PM
newguy's Avatar
Figured it out, starter relay was screwing up. Switched the rear defog relay and no noise. Slight ticking but may be a bad tooth or 2 on the flex plate
Kr.Fabs
Jul 1, 2010 08:08 AM
oisinirish
Oct 7, 2009 02:12 AM
rllamarca
Jul 20, 2009 10:58 AM
jman_08
13
Sep 25, 2008 06:29 AM
dobbist
May 22, 2005 04:48 AM
