Oil above the drain plug
Old Aug 24, 2010 | 09:38 PM
blazinloud's Avatar
Default Oil above the drain plug
hey guys, i just noticed its wet on the area above the oil drain plug with small drips sitting on the metal. does not appear to be the plug itself, although there is a hex bolt about an inch or so above the drain plug, what is that? anyone know?
where can it leak from around there other than the plug itself?
Old Aug 24, 2010 | 10:06 PM
rriddle3's Avatar
Check the oil pan bolts and the oil filter (depending on 2WD or 4WD, you didn't say) and then work upward.
gooder
May 4, 2008 04:10 PM
boulonman
Mar 5, 2007 05:10 AM
MCas86
May 11, 2006 07:40 PM
eng69
Feb 13, 2006 03:08 AM
2001Blazer4x4
Mar 2, 2005 10:45 PM
