Oil in coolant
Oil in coolant
Hello,
I have a 1996 gmc jimmy with a 4.3.
problem:I was changing the oil and wile that was draining,decided to top off the coolant.
when I poured the coolant in the radiator it came out of the oil drain hole!The oil was milky as you already have guessed.
Do I have a cracked block or?
thanks in advanced.
thanks in advanced.
RE: Oil in coolant
Most likely cause is a failed intake manifold gasket, but if you just noticed it when you serviced the cooling system, you may have damaged a LOT more.
RE: Oil in coolant
If the oil looks like a frothy milkshake, it's time for a teardown.
RE: Oil in coolant
Blown Head Gasket?
RE: Oil in coolant
That condition cost me an engine replacement not too long ago. DO NOT RUN IT LIKE THAT. pull the intake and go from there.
RE: Oil in coolant
Did your truck ever overheat? Is your radiator in decent shape? Runs fine otherwise? Dont spend your income tax refund just yet...
AcerDeucerQ
12-03-2012 06:29 AM
babeba67
04-01-2011 10:54 PM
Skeeter Cruz
03-04-2010 07:07 PM
jimhens82
12-23-2009 04:50 AM
