Oil coolant line leak?
Old Jan 29, 2008 | 12:06 AM
rastaskater's Avatar
rastaskater is an unknown quantity at this point
Default Oil coolant line leak?
I Think thats what it is? Not sure. How would i go about fixing that. Its only small drop every now and then.
95 Blazer 4x4 LT
Old Jan 29, 2008 | 12:07 AM
Default RE: Oil coolant line leak?
EDIT that second picture is after i wiped off some of the oil.
Old Jan 29, 2008 | 01:54 AM
thegr81's Avatar
I would just replace the lines and do an oil change, after replacement and oil change, turn the vehicle on and wait a few seconds then start it up to cycle the new oil through the new lines!!
Old Jan 29, 2008 | 08:32 AM
Sure looks like the beginning of a leaking line to me.
Check out the links in the related thread table at the bottom of the page. There are a few different ways you can repair this ranging from replacing the lines with either OEM or quality aftermarket pieces; cutting off the outer portion of the crimp replacing it with a hose clamp; or brazing on hydraulic fittings and having hydraulic lines made up to connect the hard lines.
Oh and the engine has to be actually running to push oil through those lines... A better way to prime everything is to remove the fuel pump relay and turn the motor over on the starter for a bit. Then reinstall the relay and start the truck.
puffy1
Oct 26, 2013 10:16 PM
jdog2pt0
Oct 2, 2012 08:08 PM
benthm7
Mar 18, 2011 06:26 PM
portcqb
Mar 27, 2010 12:07 PM
TAZ454
Jan 28, 2008 10:11 AM
