Oil Cooler Lines
Old Mar 31, 2014 | 07:45 PM
BrinkDiamond's Avatar
BrinkDiamond is on a distinguished road
Default Oil Cooler Lines
Hey guys, I know the GM oil cooler lines tend to leak after a few years. Mine needs to be replaced but I want to solve the problem and not put new ones in that will leak after awhile.
I have heard of guys using 1/2" hydraulic tractor hose lines but you need different fittings and clamps.
Is there an aftermarket oil cooler line that you guys like that doesn't leak after a few years.
Thanks for the help
Old Mar 31, 2014 | 08:52 PM
chris015's Avatar
Meh. unless you have a good hydraulic shop near by,your stuck with whatever cheap aftermarkets u can find or oem dealership stuff.
Old Apr 1, 2014 | 12:04 AM
cleburne red's Avatar
I used regular old high pressure rubber hose from the auto parts store. Using a dremel, hacksaw blade, etc, carefully cut the clamps off the old lines, and re use the original fittings. If you want to do it the proper way, have a hydraulic shop clamp the fittings to your rubber hose.
Or, the cheap way (which is what I did) get some plain old hose clamps, and stick on there. I did put two at each fitting, though. Just over a year, and not a single drop has leaked.
Old Apr 7, 2014 | 05:41 PM
rexazz2's Avatar
thinking this is the way to go but use fuel injection hose clamps instead of gear clamps
Old Apr 7, 2014 | 10:39 PM
That would be a better way than what I did. If I ever get bored one day, I might go and change 'em out. So far, so good, though.
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
Jetfixer
Jul 11, 2006 05:02 AM
eng69
Jan 31, 2006 04:55 PM
zero psi
Oct 28, 2005 04:45 PM
