Oil cooling lines
Should i get original engine to filter oil cooler lines from the dealership or from the parts store? reason im asking i just replaced the current ones that i got from rockauto when i rebuilt my engine 1 month ago and the line is already leaking from where they crimped the metal to the rubber hose.
Man them lines seem like pure trouble
Originally Posted by chestypuller
(Post 575676)
There are a few threads around that tell you how to fix the existing oil lines. That is your best bet, and it can be done while everything is still attached to the truck.
Just delete the oil adapter and cooler lines all together and put the filter on the block, eliminate all the leaking, no matter what, they will end up leaking again unless you go to a hydraulic hose shop and get some hydraulic hoses made.
(Post 575751)
Now How does this work? I like this idea. There are threads for a filter at the block? Still have to get oil to the cooler no? |
Originally Posted by J_E
(Post 575748)
The factory ones have lasted over 120000 on mine before they started leaking.. Anymore questions....
Originally Posted by jaystoy
(Post 575755)
All ya need to do is remove the remote adapter, the adapter on the block, clean up the gasket on the block, then install this part onto the block using a allen wrench and some blue thread lock on the threads gm # 14081300 and then get this oil filter WIX 51040 which will stay clear of the front shaft ect. and you are good to go. I am doing this to my first gen. I already have the gm # 14081300 for it, I just need to find time to do it. |
(Post 575751)
Just delete the oil adapter and cooler lines all together and put the filter on the block, eliminate all the leaking....
| All times are GMT -5. The time now is 09:44 AM. |
