oil drain plug?
oil drain plug?
I know this may sound stupid, but doesn't the drain plug for the oil turn the same as any nut would (righty-tighty/lefty-loosy)?
Thanks, Shane
Thanks, Shane
RE: oil drain plug?
yes it does. You are stupid...jk...lmao
RE: oil drain plug?
lmao blazin. Ok with that said why wont the dang thing screw back in?
Thanks, Shane
Thanks, Shane
RE: oil drain plug?
lefty loosey, righty tighty..lol
RE: oil drain plug?
i never followed that, always went with clockwise/counter clockwise.less room for error because someone forgets.
RE: oil drain plug?
ORIGINAL: sasquatchfound
Thanks, Shane
Thanks, Shane
Make sure there is no debris in the way of the drain hole (basically just run your finger along the threads or use a rag). Also check the threads of the plug to make sure they aren't all messed up and/or cross-treaded. If neither or those makes any difference you can pick up a new plug from you local auto parts store for under $10. If that screws in, then you plug is buggered up, if that dont work then your drain hole is messed up and needs to be re-tapped.
RE: oil drain plug?
well when i got the plug out and i was turning toward the back of my blazer, the plug had a thin strand of metal rapped around it. I;m guessing i need to rethread it. would it be cheaper for a new thread or anew pan?
Thanks, Shane
Thanks, Shane
RE: oil drain plug?
Ok, called the parts store they told me about a larger self tapping plug. Has anyone used one of these and are they safe to use on my oil pan?
Thanks, Shane
Thanks, Shane
gooder
05-04-2008 04:10 PM
boulonman
03-05-2007 05:10 AM
2001Blazer4x4
03-02-2005 10:45 PM
