oil leak
Old 06-13-2009, 10:47 AM
stevenbaty2003's Avatar
stevenbaty2003 is on a distinguished road
Default oil leak
i got a 93 s10/blazer 4.3 vortec (CPI) w/at 4x4 and 4 doors... the other day i fired her up and noticed an oil leak... its a steady drip but only when running the motor.. i checked the oil and it was low so i filled it but i parked the truck just to be safe.. the oil leaking out is black and smells and looks like engine oil.. i cannt see the leak but it is dripping from the drivier side bottom corner of the trans dust cover bolt.... my first thought was a blown rear main... does anyone have a clue how to confirm or deny that? or a possible alternative place that it might be leaking from? i need the truck back so the quicker i can get it back the better. thanks
Old 06-13-2009, 01:14 PM
You really need to get up under there and have a look where it is coming from. With the remote oil line adapter attached to the block in this location, it is possible that the retaining bolt has either loosened up or the seal on the adapter has failed.
Another possibility is that the oil pressure sending unit has failed and is leaking oil from the top of the block down.
Old 06-13-2009, 04:49 PM
or its option c the oils leaking out of the adapter cause its 10000 miles old and doesnt have enough pressure to seal stuff nomore.. rofl.. i changed the oil dropped that adapter and then put it back up... still runn like a champ at 197782 miles and counting. thx for the help
Old 06-13-2009, 07:28 PM
Originally Posted by swartlkk
*snip*... With the remote oil line adapter attached to the block in this location, it is possible that the retaining bolt has either loosened up or... *snip*
Covered as option a.1 LOL
ComputerNerdBD
03-20-2013 12:33 AM
Kaser1026
12-30-2012 05:58 PM
Bluebeastblazer57
08-11-2012 11:05 PM
BubbaBrooks
05-18-2011 08:38 PM
TAZ454
01-28-2008 10:11 AM
Quick Reply: oil leak
