Oil leak! But Where?
Old Apr 1, 2011 | 12:06 AM
Blaze the S10 4x4 Blazer's Avatar
Blaze the S10 4x4 Blazer is on a distinguished road
Ok I have a 90 s10 4.3 blazer vin z tbi newly rebuilt engine and it seems after all the pain of putting this together I have a oil leak.
I notice that the leak only occurs when the engine is running and it seems to be on the passenger side only so oil adapter is not the cause, but replaced with new anyways because old ones were worn out. The drips occur on the starter bolts and the passenger side dust cover bolts.
My suspicion is that I have one of four things occuring
1 rear main
2 valve cover
3 rear oil pan gasket
4 intake leak/ oil sending unit
In my suspicion i have checked two of these valve covers and intake/ oil sending unit.
how can i get the dust cover off to inspect if it is one of the two worst?
In addition I forgot to add I don't want to remove anything I don't have to lol
front drive shaft?
exhaust?
transmission line to rad disconnect?
thanks for replys
Last edited by swartlkk; Apr 1, 2011 at 06:16 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Apr 1, 2011 | 06:15 AM
I would look higher up, but you can pull the dust cover and have a look at the front of the flex plate. If the flex plate is dry, then the rear main is intact and sealing properly.
As far as higher up, check the back of the intake manifold, the gasket at the bottom of the distributor, and the valve cover gaskets. All three are somewhat common leak points, especially if things were opened up and not correctly reinstalled at some point in the engine's history.
Clean up the oil with some degreaser so you can get a better look at finding the source.
ComputerNerdBD
Mar 20, 2013 12:33 AM
BubbaBrooks
May 18, 2011 08:38 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
13ogart
Dec 15, 2009 02:18 AM
TAZ454
Jan 28, 2008 10:11 AM
