Oil pan gasket replacement 97' Blazer
Hello everyone. I'm new to the forum and could use some directions around here. Don't know if i'm in the right spot. I'm needing some information on the easiest/ best way to replace oil pan gasket on my 1997 S10 Blazer. Any help would be greatly appriciated.
Two options lift the motor, don't know if you can raise it enough to drop pan.
I pulled motor. I rebuilt engine and trans.
Or drop the front axle diff. I'm going to be doing that this spring
Going to replace all the seals and gaskets.
marcspector
16
10-23-2015 09:26 AM
thundergod66
11-20-2012 06:02 PM
AaronGene02
01-24-2010 11:38 AM
