oil pan leak
Old Jan 1, 2012 | 07:36 PM
benjamin tate's Avatar
benjamin tate is on a distinguished road
Default oil pan leak
yep just what the title says I just got done doing a complete engine and talk about a pain finally got everything in and running timming was a issue and so i finally got it going walked in to tell the wife her POS was done walked back out and oil leak from hell.
So my question is how hard is it to drop a oil pan on a 2000 blazer 4by4 oil leaks coming out by the timing chain cover.
Old Jan 2, 2012 | 12:34 AM
Demon's Avatar
Demon is on a distinguished road
im not going to sugar coat this for you but its no fun i was told you can do it with out lifting the engine up but i have yet to see how when i did the sas on my 2000 blazer i ended up cutting that crossmember out so now i can do the job with out any issues but you are going to have to lift the motor if not remove it completely good luck
Old Jan 2, 2012 | 12:49 PM
neo71665's Avatar
Easiest way is to pull the engine.
Buy the time you remove all the front diff and jack the engine up enough to get the pan out its less work to pull it out the top.
Chevy33
Apr 17, 2013 04:22 PM
Bluebeastblazer57
Aug 11, 2012 11:05 PM
benjamin tate
Jan 8, 2012 09:14 PM
kevin turner
Apr 9, 2010 01:21 PM
TAZ454
Jan 28, 2008 10:11 AM
