oil pan removal 04 4x4 chevy blazer
Old Nov 9, 2017 | 03:08 AM
Johnson's Avatar
Johnson is on a distinguished road
Default oil pan removal 04 4x4 chevy blazer
how do i remove the oil pan on my 04 4x4 chevy blazer
Old Nov 9, 2017 | 07:21 AM
LesMyer's Avatar
Do you have a specific question?
Old Nov 9, 2017 | 07:54 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Quoting from my 1999 factory service manual:
1. Remove and discard the engine oil level sensor ( if applicable ).
2. Remove the oil pan bolts and nuts.
3. Remove the oil pan.
4. Remove the oil pan gasket.
5. Discard the oil pan gasket.
Oh, that is once you have already removed the engine from the vehicle... you knew that right?
Old Nov 16, 2017 | 04:58 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
Default I couldn't figure out how to do it !
I just went through this learning curve to replace the timing chain. I could not figure out what was holding it on after removing all bolts !? ( In vehicle) I broke the tip off of a large craftsman screwdriver prying between the trans. bellhousing and oil pan after smacking it with a rubber mallet all over to break it loose ! No luck ! I ended up carefully removing the timing cover and reinstalling it with the pan bolts out.
Aluekard
Nov 14, 2014 10:40 PM
90in87
Oct 7, 2011 08:24 PM
Blazer Steve
Jun 22, 2010 10:39 PM
NM_Wanderer
Dec 16, 2009 03:00 PM
bobditts
Jun 18, 2009 06:38 AM
