Oil Pressure
Old Mar 4, 2026 | 01:52 AM
Smibn7's Avatar
Smibn7 is on a distinguished road
Default Oil Pressure
Hello, I have a 2000 4x4 4.3l. When I first start the blazer, my oil pressure gauge reads about 60 psi. Once the oil finally warms up it will drop down to 40 psi. However when the blazer is in idle, it will drop down to 20 psi but will jump back up to 40 once I step on the gas. Bad oil switch maybe? Any insight is greatly appreciated.
Old Mar 4, 2026 | 06:02 AM
Others should give their thoughts, but I think this is not out of the ordinary for the 4.3L and matches my experience.
Old Mar 4, 2026 | 04:38 PM
int3414's Avatar
int3414 will become famous soon enough
my 2001 jimmy does about the same thing,i really dont like it because the last two i had (2000 blazeer and the 98 jimmy ) were both higher...but i guess not to worry..?
Old Apr 22, 2026 | 08:16 AM
thegoat86's Avatar
thegoat86 is on a distinguished road
Depends usually on lots of things. How worn the crank bearings are, pump health, plugged or slightly plugged oil passages, oil temp, ect. Too many to things worry about. As long as its around 20, thats the safe pressure for the 4.3. Ideal is 40-60. Thats why they used to never mark pressure levels on the old school guages. Just safe and high.
puttster
Apr 1, 2023 05:30 PM
Kaser1026
Jan 12, 2013 09:45 PM
Opi
Sep 26, 2012 09:41 PM
punnerab
Jun 17, 2009 11:34 PM
junkmonkey
Jul 30, 2007 05:30 PM
